el_jefe_de_steak
Try this code. It searches through all the browser nodes until it finds a 3D Sketch and turns it off. This should work for setting visibility of other types of objects as well.
To set visibility, change the second parameter of the first line that starts with "Call"
Public Sub Set3DSketchVisibility()
    Dim thisAssembly As Document
    Set thisAssembly = ThisApplication.ActiveDocument
    If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject Then
        MsgBox ("This macro can only be run in assembly documents")
        Exit Sub
    End If
    'get the model browser pane
    Dim oModelBrowserPane As BrowserPane
    Set oModelBrowserPane = thisAssembly.BrowserPanes.item("Model")
    'search through all browser nodes and set visibility of sketches found
    'set the second parameter to true or false based on whether you want to hide or show 3d sketches
    Call SearchNodes(oModelBrowserPane.TopNode.BrowserNodes, True)
End Sub
Private Sub SearchNodes(oNode As BrowserNodesEnumerator, sketchVisiblilty As Boolean)
    'set instance objects
    Dim oSubNode As BrowserNode
    Dim o3DSketch As Sketch3DProxy
    'quits routine when it comes to a node that is empty
    If oNode.Count = 0 Then
        Exit Sub
    End If
    'search through nodes
    For Each oSubNode In oNode
        'if node contains child nodes, search through those
        If oSubNode.BrowserNodes.Count > 0 Then
            Call SearchNodes(oSubNode.BrowserNodes, sketchVisiblilty)
        End If
        'search for 3D Sketches and set the visiblity
        If Not oSubNode.NativeObject Is Nothing Then
            If oSubNode.NativeObject.Type = kSketch3DProxyObject Then
               Set o3DSketch = oSubNode.NativeObject
               o3DSketch.Visible = sketchVisiblilty
            End If
        End If
    Next
End Sub
