Patrick1323
805 Views, 5 Replies
Replace a style in the Part Document using API
is there a way to perform this action (replace Style) in the part document, but by code?
Labels (4)
JelteDeJong
in reply to: Patrick1323
i could not find a command for Replacing a text style. But i found a way to delete the style and copy the other. it works like this:
Dim originalStyleName As String = "ReplaceMe"
Dim replaceBy As String = "replaceWithMe"
Dim doc As PartDocument = ThisDoc.Document
Dim def As PartComponentDefinition = doc.ComponentDefinition
Dim textStyleOrg As TextStyle = Nothing
Dim textStyleNew As TextStyle = Nothing
For Each style As TextStyle In doc.TextStyles
    If (Style.Name = originalStyleName) Then
        textStyleOrg = Style
    End If
    If (Style.Name = replaceBy) Then
        textStyleNew = Style
    End If
Next
textStyleOrg.Delete()
textStyleNew.Copy(originalStyleName)
Jelte de Jong
Blog: hjalte.nl - github.com
Patrick1323
in reply to: JelteDeJong
Hello JelteDeJong,
thanks for your response, unfortunately I can't delete styles which are in use.
This will throw an exception:
As far as I know there's no way to create a "Standard" like for the drawing styles, and set that new standard as the active one. Then I would be able to delete the old style...
Hello Patrick1323,
I don't know what you want exatly, but could it be a solution to redefine the Style in Style library as you want and then Update the Stile from Style library?
extStyleOrg.UpdateFromGlobal()
Best Regards
Wolfgang
Hello Wolfgang,
thats not want to do, I want to delete a style in use.
best regards
Patrick
JelteDeJong
does this work for you:
Dim originalStyleName As String = "Note Text (ANSI) - 3DA"
Dim replaceBy As String = "Sketch Text (ANSI) - 3DA"
    End If
    End If
Next
' in this part all properties from textStyleNew are copyed to textStyleOrg
Dim type As Type = GetType(Inventor.TextStyle)
For Each prop As Reflection.PropertyInfo In type.GetProperties()
    If (prop.CanWrite) Then
        If (prop.Name = "Name" Or prop.Name = "_Name") Then
            Continue For
        End If
        Dim obj = prop.GetValue(textStyleNew)
        prop.SetValue(textStyleOrg, obj)
    End If
Next
' both styles are now the same.
Jelte de Jong
