10-22-2020
02:19 PM
- Mute
- Permalink
- Report
10-22-2020
02:19 PM
I could not find a way using the api. But you could try to copy the InventorCustomization file.
Dim inventorVersion As String = "2020" Dim destinationPath As String = "c:\temp\" Dim fileName As String = "InventorCustomization.xml" Dim appdataPath As String = System.Environment.ExpandEnvironmentVariables("%APPDATA%") Dim lastPartPath As String = String.Format("Autodesk\Inventor {0}", inventorVersion) Dim fullSourcePath As String = System.IO.Path.Combine(appdataPath, lastPartPath, fileName) Dim fullDestinationPath As String = System.IO.Path.Combine(destinationPath, fileName) If (System.IO.File.Exists(fullSourcePath)) Then ' copy the customization file to a save location System.IO.File.Copy(fullSourcePath, fullDestinationPath, True) Else MsgBox("could Not find customization file") End If ' do something else ' and return the customization file to its original location System.IO.File.Copy(fullDestinationPath, fullSourcePath, True)
Jelte de Jong
Blog: hjalte.nl - github.com
