gma
859 Views, 2 Replies
Set subassembly to flexible by ilogic.
Is it possible to always set a assembly to flexible... So when i put it in an assembly, it will be standard flexible.
If not.
Is it possible to make an ilogic so when I put a subassembly into an assembly, I can run a rule so every subassembly starting with "StandardLeg" will be flexble?
Thanks in advance.
