Hey Markus, thanks for the reply. I was actually looking into that same method but couldn't figure out how to do the undo checkout of specific occurrences. From what I saw, running that execute, would check-in all the components unless each component is opened individually.
Is that what you meant by "activate each component"?
If so, I was concerned that would drain a lot of resources (not sure if that's true), hence why I was looking for a way to specify the component for the Undo Checkout. From what I can tell, there is no way to do that, except for perhaps adding a new class that will connects to Vault via the Vault API and specify which file to Undo Checkout.
