TA.Fehr
in reply to: TA.Fehr
I know it's been a while, but this is an ammendment to the code that I had originally posted so it will be relevant to anyone who will use this in the future.
I've added functionality for converting linetypes as well as correcting an issue with legacy bend lines causing issue with the linetype.
Function Translate_ini(ini) As String
        'Create stringbuilder to re-create ini
        Dim exportini As New StringBuilder
        'Create a string that contains the invisible layers to append to the file
        Dim invisLayers = ""
        'Iterate through each line
        For Each line As String In System.IO.File.ReadAllLines(ini)
            'Create a blank string to convert each line of the ini file into a readable output string
            Dim kernel = ""
            'Set the program compatibility
            If line.Contains("AUTOCAD VERSION") Then
                'Set the year
                Dim year As Integer = Strings.Right(line, 4)
                'Append the header file to the output
                exportini.Append("FLAT PATTERN DXF?AcadVersion=" & year)
            End If
            'Each layer contains an =, this differentiates between the comment lines which contain []
            If line.Contains("=") Then
                Dim title = ""
                Dim header = ""
                Select Case True
                    'Create a title so we can loop through the different layer types rather than create a case for each
                    Case line.Contains("Tangent")
                        header = "TANGENT"
                        title = "&TangentLayer"
                    Case line.Contains("Bend") And line.Contains("Front")
                        header = "BEND"
                        title = "&BendUpLayer"
                    Case line.Contains("Bend") And line.Contains("Back")
                        header = "BEND_DOWN"
                        title = "&BendDownLayer"
                    Case line.Contains("Tool Centers") And line.Contains("Front")
                        header = "TOOL_CENTER"
                        title = "&ToolCenterLayer"
                    Case line.Contains("Tool Centers") And line.Contains("Back")
                        header = "TOOL_CENTER_DOWN"
                        title = "&ToolCenterDownLayer"
                    Case line.Contains("Arc Centers")
                        header = "ARC_CENTERS"
                        title = "&ArcCentersLayer"
                    Case line.Contains("Outer Profile")
                        header = "OUTER_PROFILE"
                        title = "&OuterProfileLayer"
                    Case line.Contains("Inner Profile")
                        header = "INTERIOR_PROFILES"
                        title = "&InteriorProfilesLayer"
                    Case line.Contains("Feature Profile") And line.Contains("Front")
                        header = "FEATURE_PROFILES"
                        title = "&FeatureProfilesLayer"
                    Case line.Contains("Feature Profile") And line.Contains("Back")
                        header = "FEATURE_PROFILES_DOWN"
                        title = "&FeatureProfilesDownLayer"
                    Case line.Contains("Alternate Rep") And line.Contains("Front")
                        header = "ALTREP_FRONT"
                        title = "&AltRepFrontLayer"
                    Case line.Contains("Alternate Rep") And line.Contains("Back")
                        header = "ALTREP_BACK"
                        title = "&AltRepBackLayer"
                    Case line.Contains("Unconsumed Sketches")
                        header = "UNCONSUMED_SKETCHES"
                        title = "&UnconsumedSketchesLayer"
                    Case line.Contains("Tangent Roll Lines")
                        header = "ROLL_TANGENT"
                        title = "&TangentRollLinesLayer"
                    Case line.Contains("Roll Lines")
                        header = "ROLL"
                        title = "&RollLinesLayer"
                    Case line.Contains("REBASE GEOMETRY")
                        If line.Contains("Yes") Then
                            title = "&RebaseGeometry=True"
                        Else
                            title = "&RebaseGeometry=False"
                        End If
                    'Case Line.Contains("GROUP GEOMETRY")
                    '    If Line.Contains("Yes") Then
                    '        Title = "MergeProfilesIntoPolyline=True"
                    '    Else
                    '        Title = "MergeProfilesIntoPolyline=False"
                    '    End If
                    Case line.Contains("REPLACE SPLINE")
                            title = "&MergeProfilesIntoPolyline=True"
                        Else
                            title = "&MergeProfilesIntoPolyline=False"
                        End If
                    Case line.Contains("SPLINE SIMPLIFICATION METHOD")
                        If line.Contains("Linear") Then
                            title = "&SimplifySplines=True"
                        Else
                            title = "&SimplifySplines=False"
                        End If
                    Case line.Contains("CHORD_TOLERANCE")
                        'Trim off identifyer
                        title = Strings.Right(line, Len(line) - InStrRev(line, "="))
                        'replace syntax
                        title = Replace(title, ".", ",")
                        'trim off units
                        If title.Contains(" ") Then
                            title = "&SplineTolerance =" & Strings.Left(title, InStr(title, " ") - 1)
                        Else
                            title = "&SplineTolerance =" & title
                        End If
                End Select
                'Split the line into its individual components
                Dim splitArray As String() = line.Split(";")
                Dim split As String
                'Iterate through each detail and convert it into a readable format
                If header = "" AndAlso title <> "" Then
                    kernel = title
                Else
                    For Each split In splitArray
                        'Differentiate visible layers from invisible layers
                        If line.Contains("Visibility=ON") Then
                            'Go through each layer option and convert accordingly
                            Select Case True
                                Case split.Contains("=IV")
                                    'Write the 1st kernel of the tangent line
                                    kernel = title & "=IV_" & header
                                Case split.Contains("LinePattern")
                                    Select Case Strings.Right(split,len(split) - InStrRev(split,"="))
                                        Case 28100 'continuous
                                            kernel = kernel & title & "LineType=37633"
                                        Case 28101 'dashed
                                            kernel = kernel & title & "LineType=37634"
                                        Case 28102 'dashed space
                                            kernel = kernel & title & "LineType=37641"
                                        Case 28103 'long dash dotted
                                            kernel = kernel & title & "LineType=37642"
                                        Case 28104 ' long dash double dot
                                            kernel = kernel & title & "LineType=37635"
                                        Case 28105 'long dash triple dot
                                            kernel = kernel & title & "LineType=37643"
                                        Case 28106 'dotted
                                            kernel = kernel & title & "LineType=37636"
                                        Case 28107'chain
                                            kernel = kernel & title & "LineType=37644"
                                        Case 28108'double dash chain
                                            kernel = kernel & title & "LineType=37637"
                                        Case 28109'dash double dot
                                            kernel = kernel & title & "LineType=37645"
                                        Case 28110' dash dot
                                            kernel = kernel & title & "LineType=37638"
                                        Case 28111'double dash dot
                                            kernel = kernel & title & "LineType=37646"
                                        Case 28112'double dash double dot
                                            kernel = kernel & title & "LineType=37639"
                                        case 28113 'dash triple dot
                                            kernel = kernel & title & "LineType=37647"
                                        Case 28114'double dash triple dot
                                            kernel = kernel & title & "LineType=37640"
                                    End Select
                                Case split.Contains("LineWeight")
                                    'Lineweights have the same syntax so I've tagged it onto the converted identifyer
                                    split = Replace(split, ";", "")
                                    kernel = kernel & title & Replace(split, ".", ",")
                                Case split.Contains("Color")
                                    'same as lineweights
                                    kernel = kernel & title & Replace(split, ",", ";")
                                Case split = ""
                                    'the last split returns nothing so don't include anything in the kernel
                                Case Else
                                    'Add flat pattern geometry options
                            End Select
                        ElseIf Not line.Contains("[") AndAlso header <> "" Then
                            'for invisible layers, compile a list and tag on at the end
                            If invisLayers = "" Then
                                invisLayers = "IV_" & header
                            Else
                                invisLayers = invisLayers & ";IV_" & header
                            End If
                            Exit For
                        End If
                    Next
                End If
                'add the compiled kernel before moving to the next line
                If kernel <> "" Then exportini.Append(kernel)
            End If
        Next
        'After all the lines are read, tack on the invisible layers
        If invisLayers <> "" Then exportini.Append("&InvisibleLayers=" & invisLayers)
        'Return the string as the output for the dxf
        Return exportini.ToString
    End Function
