527 Views, 2 Replies
Automatic comparison of details and sections alphabetically
Hi to all,
when generating drawing documentation, it is necessary to work with details and sections. If I find that one of the details or cuts does not suit me and I delete it, then it is not possible to automatically compare the individual designations so that the letters go alphabetically. Is it possible to solve this with the iLogic rule?
JhoelForshav
Hi @Anonymous
There's a VBA code posted about this by @Anonymous here:
https://forums.autodesk.com/t5/inventor-ideas/drawings-re-number-detail-amp-section-views/idi-p/6276556
As an iLogic rule it'd look something like this :slightly_smiling_face:
Sub Main
Dim oDoc As DrawingDocument
Dim oSheet As Sheet
Dim oView As DrawingView
Dim iter As Long
'check if active document is a drawing
If ThisApplication.ActiveDocument.DocumentType <> kDrawingDocumentObject Then
    Exit Sub
End If
oDoc = ThisApplication.ActiveDocument
iter = 1
'Rename detail and section view identifiers on all sheets
For Each oSheet In oDoc.Sheets
    For Each oView In oSheet.DrawingViews
        If oView.ViewType = kDetailDrawingViewType Or oView.ViewType = kSectionDrawingViewType Then
            oView.Name = num2Letter(iter)
            iter = iter + 1
            If InStr(1, num2Letter(iter), "I") > 0 Or InStr(1, num2Letter(iter), "O") > 0 Or InStr(1, num2Letter(iter), "Q") > 0 Then
                iter = iter + 1
            End If
        End If
    Next oView
Next oSheet
End Sub
Public Function num2Letter(num As Long) As String
'converts long to corresponding alpha
'Ex. 1 = A, 28 = AB
remain = num Mod 26
whole = Fix(num / 26)
If num < 27 Then
    If remain = 0 Then
        num2Letter = "Z"
    Else
        num2Letter = Chr(remain + 64)
    End If
Else
    If remain = 0 Then
        num2Letter = Chr(whole + 63) & "Z"
    Else
        num2Letter = Chr(whole + 64) & Chr(remain + 64)
    End If
End If
End Function
in reply to: JhoelForshav
thank you, it works great.
