dutt.thakar
@Anonymous
Component.AddiPart does not work for iAssemblies.
What you can do is use these snippets instead
Components.Add("xyz:1","xyz.iam") - To add the iAssembly inside your assembly
iPart.FindRow("xyz:1","Member","=","A") - To change the row that you want to in that iAssembly.
Please accept this if this has answered your question.
Dutt Thakar
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
