09-23-2020
01:29 PM
- Mute
- Permalink
- Report
09-23-2020
01:29 PM
hi, does this work or you?
Dim doc As DrawingDocument = ThisApplication.ActiveDocument ' Make a list of the views. For use later Dim knowViews As List(Of String) = New List(Of String) For Each view As DrawingView In doc.ActiveSheet.DrawingViews knowViews.Add(View.Name) Next ' Create a drawingview Dim sFileName = oPartTest.FullFileName ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, sFileName) Dim oTest = ThisApplication.CommandManager.ControlDefinitions.Item("DrawingBaseViewCmd") oTest.Execute2(True) ' find the view that was just added and (re)start command For Each view As DrawingView In doc.ActiveSheet.DrawingViews If (knowViews.Contains(View.Name) = False) Then doc.SelectSet.Clear() doc.SelectSet.Select(View) ThisApplication.CommandManager.ControlDefinitions.Item("DrawingViewEditCtxCmd").Execute() Exit For End If Next
Jelte de Jong
Blog: hjalte.nl - github.com
