J-Camper
I condensed the code a little and change the Try/Catch into a loop:
Sub Main()
	If ThisApplication.ActiveDocumentType <> kDrawingDocumentObject Then MessageBox.Show("This rule is designed to only work in drawing documents.", "Wrong Document Type") : Exit Sub
Start:
	Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
    ' Select a drawing view.
    Dim oView As DrawingView = ThisApplication.CommandManager.Pick(kDrawingViewFilter, "Select a drawing view.")
    'Set a reference to the active sheet.
    Dim oSheet As Sheet = oView.Parent
	Dim dXval As Double  = oView.Left
	Dim dYval As Double = oView.Center.Y
	Dim dLeftXval As Double = dXval - 3
    'add height to y value
    Dim dUpperYval As Double = dYval + (0.5 * oView.Height) + 1
    'subract  height To y value
    Dim dLowerYval As Double = dYval - (0.5 * oView.Height) - 1
    Dim oPoint1 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(dLeftXval,dUpperYval)
    Dim oPoint2 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(dLeftXval,dLowerYval)
    'create a new sketch For the section
    Dim oDrawingSketch As DrawingSketch = oView.Sketches.Add
	Dim oSketchPoint1 As Point2d = oDrawingSketch.SheetToSketchSpace(oPoint1)
    Dim oSketchPoint2 As Point2d = oDrawingSketch.SheetToSketchSpace(oPoint2)
	oDrawingSketch.Edit
    Dim oSketchLine As SketchLine = oDrawingSketch.SketchLines.AddByTwoPoints(oSketchPoint1,oSketchPoint2)
    oDrawingSketch.ExitEdit
    'set the location for the view
    Dim olocal As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(6,oView.Center.Y)
    Dim oView2 As SectionDrawingView = oSheet.DrawingViews.AddSectionView(oView, oDrawingSketch, olocal,DrawingViewStyleEnum.kFromBaseDrawingViewStyle, Nothing, , , False, True)
    oDrawingSketch.Visible = True
	'AutoGenerate PartList
	Dim oPlacementPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(dLeftXval+22, dUpperYval+3)
    iLogicVb.UpdateWhenDone = True
	For Each pl As PartsList In oSheet.PartsLists
		If pl.ReferencedDocumentDescriptor.FullDocumentName = oView.ReferencedDocumentDescriptor.FullDocumentName
			GoTo Done 'Parts list Exists so exiting loop to avoid making again
		End If
	Next
	'If exiting loop normally, then Partslist was not found so we will make it
	Dim oPartslist As PartsList = oSheet.PartsLists.Add(oView, oPlacementPoint)
Done :
	'Selection if you want to continue with section cut
	Dim oChoice As String = MsgBox(" Do you want to create another section cut?", vbQuestion + vbYesNo + vbDefaultButton2, "Section Cut")
    If oChoice = vbYes Then GoTo Start
End Sub
Let me know if you're still having issues.
