JelteDeJong
does this work for you?
[iLogic]
Start:
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
' Select a drawing view.
Dim oView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a drawing view.")
'Set a reference to the active sheet.
Dim oSheet As Sheet = oView.Parent
Dim dXval As Double = oView.Left
Dim dYval As Double = oView.Center.Y
Dim dLeftXval As Double = dXval - 3
'add height to y value
Dim dUpperYval As Double = dYval + (0.5 * oView.Height) + 1
'subract  height To y value
Dim dLowerYval As Double = dYval - (0.5 * oView.Height) - 1
Dim oPoint1 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(dLeftXval, dUpperYval)
Dim oPoint2 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(dLeftXval, dLowerYval)
'create a new sketch For the section
Dim oDrawingSketch As DrawingSketch = oView.Sketches.Add
Dim oSketchPoint1 As Point2d = oDrawingSketch.SheetToSketchSpace(oPoint1)
Dim oSketchPoint2 As Point2d = oDrawingSketch.SheetToSketchSpace(oPoint2)
oDrawingSketch.Edit()
Dim oSketchLine As SketchLine = oDrawingSketch.SketchLines.AddByTwoPoints(oSketchPoint1, oSketchPoint2)
oDrawingSketch.ExitEdit()
'set the location for the view
Dim olocal As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(6, oView.Center.Y)
Dim oView2 As SectionDrawingView = oSheet.DrawingViews.AddSectionView(oView, oDrawingSketch, olocal, DrawingViewStyleEnum.kFromBaseDrawingViewStyle, Nothing, , , False, True)
oDrawingSketch.Visible = True
'AutoGenerate PartList
Dim oPlacementPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(dLeftXval + 22, dUpperYval + 3)
' check if we can find a partlist that belongs to the seelcted view
Dim viewPartName = oView.ReferencedFile.FullFileName
Dim aPartListIsFound = False
For Each pl As PartsList In oSheet.PartsLists
    Dim plFileName = pl.ParentView.ReferencedFile.FullFileName
    If (viewPartName.Equals(plFileName)) Then
        aPartListIsFound = True
    End If
Next
' If none partslist was found then create it.
If (aPartListIsFound = False) Then
    oSheet.PartsLists.Add(oView, oPlacementPoint)
End If
'Selection if you want to continue with section cut
Dim oChoice As String
oChoice = MsgBox(" Do you want to create another section cut?", vbQuestion + vbYesNo + vbDefaultButton2, "Section Cut")
If oChoice = vbYes Then
    GoTo Start
Else
End If
Jelte de Jong
Blog: hjalte.nl - github.com
