btomosonEYBLL
in reply to: WCrihfield
Which version & release year of Inventor are you using?
Inventor 2021.1.1
Can you see your iLogic browser?
Yes
If it is not showing up next to your Model Browser, you may need to either:
  • go to your Manage tab > iLogic panel > and click on "iLogic Browser".
  • or click the little plus sign (+) next to the Model tab and choose "iLogic".
It is showing
Are you expanding the iLogic Tab (Dockable Window)?
Attached is my iLogic dock showing what I can see for named geometry. It gives a "label visibility" option
Named Entities became available in Inventor 2019, I believe.
I can name entities, my problem is that I can not see these entities in the iLogic rule screen to be able to interact with them.
Attached is a picture from the tutorial showing the named items in the model browser on the rule screen.
Also attached is what I can see on my rule screen.
