- Mute
- Permalink
- Report
Sorry I didn't get back with you sooner on this matter in the last post. I got caught away at work.
Here's what I was working on yesterday for you.
There are several lines commented out, just to show some optional possibilities.
I was actually thinking specifying the font and its size by specifying the TextStyle you wanted to use, instead of the more difficult route of specifying the individual Font Name, and Font Size, etc.
Then putting a block of code to check the resulting text size compared to the text box size, then offering some options to help correct any issues, in a few different ways like in the following code.
This code I am testing with an A-Size sheet (8.5 in x 11 in), and have a simple rectangle border that is .25 in from all sides of the sheet. And the rectangle for my text box is being translated to Inches by multiplying by 2.54.
It places the TextBox in the lower left corner of this border (just as an example).
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Drawing Documents.",vbOKOnly, "WRONG DOCUMENT TYPE")
Return
End If
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim oSheet As Inventor.Sheet = oDDoc.ActiveSheet
Dim oBorder As Inventor.Border = oSheet.Border
Dim oTStyles As TextStylesEnumerator = oDDoc.StylesManager.TextStyles
Dim oTStyle As TextStyle
Dim oTStylesNames As New List(Of String)
For Each oTStyle In oTStyles
oTStylesNames.Add(oTStyle.Name)
Next
Dim oTStyleName As String = InputListBox("Select a TextStyle for this TextBox.",oTStylesNames," ","Available TextStyles")
oTStyle = oTStyles.Item(oTStyleName)
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oPoint1 As Point2d = oBorder.RangeBox.MinPoint
Dim oPoint2 As Point2d = oTG.CreatePoint2d(oPoint1.X + (3*2.54), oPoint1.Y + (.75*2.54))
Dim oSketch As DrawingSketch = oSheet.Sketches.Add
oSketch.Edit
Dim oText As String = InputBox("Enter new Title Text", " ")
'Dim oFText As String = "<StyleOverride Font='Simplex' FontSize='18' Bold-'True' Italic='False' Underline='False'>" & oText & "</StyleOverride>"
'Dim oTextBox As Inventor.TextBox = oSketch.TextBoxes.AddByRectangle(oPoint1, oPoint2, oFText)
Dim oTextBox As Inventor.TextBox = oSketch.TextBoxes.AddByRectangle(oPoint1, oPoint2, oText, oTStyle)
'oTextBox.ShowBoundaries = True
'iLogicVb.DocumentUpdate
'MsgBox("There are " & oTextBox.BoundaryGeometry.Count & " entities within oTextBox.BoundaryGeometry.")
'For Each oSE As SketchEntity In oTextBox.BoundaryGeometry
' oSE.SketchOnly = False
' oSE.Construction = False
' oSketch.GeometricConstraints.AddGround(oSE)
'Next
FitCheck :
If oTextBox.FittedTextWidth > oTextBox.Width Then
oAns = MsgBox("The text is wider than the text box." & vbCrLf & _
"Do you want to: Reduce Font Size [Yes], Edit the contents [No], or Leave it that way [Cancel]?", vbYesNoCancel + vbQuestion, " ")
If oAns = vbYes Then
oNewTStyleName = InputListBox("Select a TextStyle for this TextBox.",oTStylesNames," ","Available TextStyles")
oTextBox.Style = oTStyles.Item(oNewTStyleName )
'Then GoTo FitCheck (the beginning Of this Size Check Process)
GoTo FitCheck
ElseIf oAns = vbNo Then
oTextBox.Text = InputBox("Edit contents.", " ", oTextBox.Text)
GoTo FitCheck
End If 'Don't really need to deal with what happens when they choose Cancel.
End If
oSketch.ExitEdit
Let me know how this works for you.
Wesley Crihfield
(Not an Autodesk Employee)
