mikejones
in reply to: JhoelForshav
Thanks for the reply @JhoelForshav
I tried the code you suggested but it stops with the following error
Error in rule: New Hopper, in document: Hopper Fabrication.iam
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
And this from the More Info tab
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.Documents.Add(DocumentTypeEnum DocumentType, String TemplateFileName, Boolean CreateVisible)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Any ideas?
Mike
Autodesk Certified Professional
