mcgyvr
@Anonymous wrote:
Is there a way to automatically create one or more Parameters with a rule so that when i create a new part or assembly I automatically always have a set of parameters.
Sure..
You could also just add those parameters to your template files so they are always there upon starting a new file from those templates.  No coding required for that.
Here is help on how to create new custom templates (you can also just modify the existing ones)
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Inventor-Help/files/GUID-598A0524-BEF9-4F48-8650-69372D5E7CFE-htm.html
Here is some help on creating user parameters via ilogic
https://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-DB91F7F6-842C-4849-A856-1003F8B7C576
Let us know if you need additional help and be specific
