- Mute
- Permalink
- Report
See if this works for you.
From the looks of the StatusBar message, this is just a portion of a larger code, so I'm not sure if this is the main part, or if this is the lower Sub part. If this portion of the code is not the main top code in your rule, you likely need to change Sub Main() to something else like Sub FlatPatternToSAT().
I also put a check in there, because the WorkspacePath can be empty, if not defined within your Project file. I also showed an alternate way to get that info, commented out.
As far as the version, I couldn't find any examples of other entries in place of "ACIS SAT".
I tried using the Sub: DataIO.GetOutPutFormats(), but it was constantly throwing errors, so I never was able to get the results. I tried it on the ComponentDefinition, the FlatPattern, on FlatPattern.SolidBodies.Item(1).DataIO, but always errors. There is very little documentation about using DataIO's on here, other that where others have tried to use it at some point in the past. The only official example using it is for DXF's.
Sub Main
Dim oPDoc As PartDocument = ThisApplication.ActiveDocument
If iProperties.Value("Project", "Revision Number") = "" Then
iProperties.Value("Project", "Revision Number") = "0"
End If
Dim oRev As String = iProperties.Value("Project", "Revision Number")
''If oPDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
If oPDoc.PropertySets.Item("Design Tracking Properties").Item("Document SubType Name").Value = "Sheet Metal" Then
Dim oSMDef As SheetMetalComponentDefinition = oPDoc.ComponentDefinition
If oSMDef.FlatPattern Is Nothing Then
oSMDef.Unfold
oSMDef.FlatPattern.ExitEdit
End If
'' Dim oWSP As String = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath
If ThisDoc.WorkspacePath = "" Then
MsgBox("ThisDoc.WorkspacePath is empty (not defined). Exiting.", vbOKOnly + vbExclamation, "WORKSPACE NOT DEFINED")
Return 'or Exit Sub
End If
Dim oPathSat As String = ThisDoc.WorkspacePath & "\SAT\"
If Not System.IO.Directory.Exists(oPathSat) Then
System.IO.Directory.CreateDirectory(oPathSat)
End If
'' Version = 7
Dim oFileName As String = oPathSat & ThisDoc.FileName(False) & "_REV-" & oRev & ".sat"
Try
oSMDef.FlatPattern.DataIO.WriteDataToFile("ACIS SAT", oFileName)
Catch oEx As Exception
MsgBox("DataIO.WriteDataToFile() failed!" & vbCrLf & _
"Error Message is as follows:" & vbCrLf & _
oEx.Message & vbCrLf & vbCrLf & _
"Error Source is as follows:" & vbCrLf & _
oEx.Source & vbCrLf & vbCrLf & _
"Error StackTrace is as follows:" & vbCrLf & _
oEx.StackTrace & vbCrLf & vbCrLf & _
"Error Type.ToString is as follows:" & vbCrLf & _
oEx.GetType.ToString, vbOKOnly + vbInformation, " ")
End Try
Else
ThisApplication.StatusBarText = ThisDoc.FileName(False) & " Is not in a sheet metal state, convert to sheetmetal and create flat pattern first --- Jumping to next part"
End If
End Sub
Wesley Crihfield
(Not an Autodesk Employee)
