yvandelafontaine
685 Views, 4 Replies
ilogic Export Sheet metal flat pattern to .SAT
I'm trying to tweak my code (global rule) to export the flat pattern to .sat in format 7.0 (INV2020), it does so but always the folded model. What am I missing???
'On Error GoTo ErrorTrapper:
If iProperties.Value("Project", "Revision Number") = "" Then
iProperties.Value("Project", "Revision Number") = "0"
End If
oRev = iProperties.Value("Project", "Revision Number")
Dim curDoc = ThisApplication.ActiveDocument
If curDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
    Dim oDoc As PartDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oCompDef As SheetMetalComponentDefinition
    oCompDef = oDoc.ComponentDefinition
	'[ Ensure this part has a flat pattern
				If oCompDef.FlatPattern Is Nothing Then
				oCompDef.Unfold
				Else
				End If
				RuleParametersOutput()
	oCompDef.FlatPattern.Edit
	Dim sOut As String
    Dim sPATH As String
	oPathSat = ThisDoc.WorkspacePath() & "\SAT\"
	'[ Ensure this folder exist
	'Check For the SAT folder And create it If it does Not exist
	If Not System.IO.Directory.Exists(oPathSat) Then
	System.IO.Directory.CreateDirectory(oPathSat)
	End If
	Version = 7
	Dim sFname As String
	sFname = oPathSat & ThisDoc.FileName(False) & "_REV-" & oRev & ".sat"
oDoc.SaveAs(sFname, True)
	'oCompDef.SaveAs(sFname ,False)
       'oCompDef.DataIO.WriteDataToFile( "ACIS SAT", sFname)
	'oCompDef.DataIO.WriteDataToFile( nsOut, nsFname)
	oCompDef.FlatPattern.ExitEdit
Else
ThisApplication.StatusBarText = ThisDoc.FileName(False) & " Is not in a sheet metal state, convert to sheetmetal and create flat pattern first --- Jumping to next part"
End If
Labels (2)
