- Mute
- Permalink
- Report
I used this example from Inventor API help
Public Sub CopyBodyFromPartToPart()
' The first portion of this program creates an assembly so that the
' copy body API can be demonstrated. Any assembly could potentially
' be used, but the sample is simpler if it's for a specific case.
' This creates an assembly that contains two parts. An interesting
' aspect of the sample is that the assembly and parts only exist
' in memory and are not written to disk. Filenames are assigned,
' so that if you perform a Save they will be written to disk using
' the specified filenames.
' Create a new assembly.
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.Documents.Add(kAssemblyDocumentObject, ThisApplication.FileManager.GetTemplateFile(kAssemblyDocumentObject))
' Define the filename for the assembly. It won't be saved at this point, but
' this name will be used if the assembly is saved later by the user.
oAsmDoc.FullFileName = "C:\Users\TCuser\Documents\Inventor\Kompozitor\CopyFaces\CopyBodyTestAsm.iam"
' Create a new part, invisibly.
Dim oPartDoc1 As PartDocument
Set oPartDoc1 = ThisApplication.Documents.Add(kPartDocumentObject, ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject), False)
' Define the filename for the part. It won't be saved at this point, but
' this name will be used if the part is saved later by the user.
oPartDoc1.FullFileName = "C:\Users\TCuser\Documents\Inventor\Kompozitor\CopyFaces\CopyBodyTestPart1.ipt"
' Set a reference to the transient geometry object.
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
Dim oCompDef As PartComponentDefinition
Set oCompDef = oPartDoc1.ComponentDefinition
' Create an extrude feature.
Dim oSketch As PlanarSketch
Set oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes.Item(1))
Call oSketch.SketchCircles.AddByCenterRadius(oTG.CreatePoint2d(0, 0), 2)
Dim oProfile As Profile
Set oProfile = oSketch.Profiles.AddForSolid
Dim oExtrudeDef As ExtrudeDefinition
Set oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kJoinOperation)
Call oExtrudeDef.SetDistanceExtent(3, kPositiveExtentDirection)
Dim oExtrude As ExtrudeFeature
Set oExtrude = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
' Create a second extrude feature as a work surface.
Set oSketch = oPartDoc1.ComponentDefinition.Sketches.Add(oPartDoc1.ComponentDefinition.WorkPlanes.Item(1))
Call oSketch.SketchLines.AddAsTwoPointRectangle(oTG.CreatePoint2d(-3, -3), oTG.CreatePoint2d(3, 3))
Set oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kSurfaceOperation)
Call oExtrudeDef.SetDistanceExtent(1.5, kPositiveExtentDirection)
' Insert the occurrence into the assembly using a somewhat arbitrary position.
Dim oMatrix As Matrix
Set oMatrix = oTG.CreateMatrix
Call oMatrix.Translation.AddVector(oTG.CreateVector(2, 3, 4))
Call oMatrix.SetToRotation(0.5, oTG.CreateVector(1, 0, 0), oTG.CreatePoint(2, 3, 4))
Dim oOcc1 As ComponentOccurrence
Set oOcc1 = oAsmDoc.ComponentDefinition.Occurrences.AddByComponentDefinition(oPartDoc1.ComponentDefinition, oMatrix)
' Create a second new part, invisibly.
Dim oPartDoc2 As PartDocument
Set oPartDoc2 = ThisApplication.Documents.Add(kPartDocumentObject, ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject), False)
oPartDoc2.FullFileName = "C:\Users\TCuser\Documents\Inventor\Kompozitor\CopyFaces\CopyBodyTestPart2.ipt"
' Insert the second part into the assembly using a somewhat arbitrary position.
Call oMatrix.Translation.AddVector(oTG.CreateVector(-1, -1, -1))
Call oMatrix.SetToRotation(0.5, oTG.CreateVector(1, 1, 0), oTG.CreatePoint(1, 1, 1))
Dim oOcc2 As ComponentOccurrence
Set oOcc2 = oAsmDoc.ComponentDefinition.Occurrences.AddByComponentDefinition(oPartDoc2.ComponentDefinition, oMatrix)
' Get the surface body from the first part that represents the work surface.
' In this case we know there's only one work surface so this just gets the
' first work surface in the collection.
Dim oWorkSurface As WorkSurface
Set oWorkSurface = oPartDoc1.ComponentDefinition.WorkSurfaces.Item(1)
Dim oBody As SurfaceBody
Set oBody = oWorkSurface.SurfaceBodies.Item(1)
' Define the matrix to use in copying the surface body from one part to
' another. Any matrix can be used, but in this case I want the position
' of the body to be the same with respect to assembly space. Because
' the occurrences are in different positions within the assembly the matrix
' needs to take into account the transfrom from one occurrence to the other.
' Get the transform from the occurrence where the surface body currently exists.
' This defines the tranform of the surface body into assembly space.
Set oMatrix = oOcc1.Transformation
' Get the matrix of the second occurrence and invert it.
' The inverse of the second occurrence's transform defines the tranform from
' assembly space into that occurrence's part space.
Dim oMatrix2 As Matrix
Set oMatrix2 = oOcc2.Transformation
oMatrix2.Invert
' Combine these matrices.
Call oMatrix.PreMultiplyBy(oMatrix2)
' Copy the surface body from the first part into the second. You shouldn't
' see anything graphically change because the new body is directly on top of
' the existing body, but it can be verified because the new body is in
' the second part.
'Call oPartDoc2.ComponentDefinition.Features.NonParametricBaseFeatures.Add(oBody, oMatrix)
Dim oDerPartDef As DerivedPartCoordinateSystemDef
Set oDerPartDef = oPartDoc2.ComponentDefinition.ReferenceComponents.DerivedPartComponents.CreateCoordinateSystemDef(oPartDoc1.FullFileName)
oDerPartDef.ExcludeAll
oDerPartDef.IncludeAllurfaces = kDerivedIndividualDefined
oDerPartDef.Surfaces.Item(1).IncludeEntity = True
Call oPartDoc2.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Add(oDerPartDef)
End Sub
First time everything is fine.I closed created assembly and deleted created files from disc. But second time subroutine stopped on
with message: Run-time error'5': Invalid procedure call or argument.
All I need to do is to close Inventor and run again, and I have next one shot.
Is there any way to purge Inventor from residual files in memory?
- Mute
- Permalink
- Report
Try this:
ThisApplication.Documents.CloseAll(True)
To close all unreferenced files in Inventors memory ![]()
Jhoel Forshav
Download my free Inventor Addin - Hole Projector
LinkedIn | Ideas | Contributions | Blog posts | Website
- Mute
- Permalink
- Report
There is another similar tool you can use that works closely with the method Joel mentioned.
oDoc.ReleaseReferenceHere is the pop-up info for this Sub.
Wesley Crihfield
(Not an Autodesk Employee)
- Mute
- Permalink
- Report
Both solution can be accepted but IMPORTANT notice:
They must be implement on the end of Sub CopyBodyFromPartToPart().
first implementation is:
oPartDoc1.ReleaseReference
oPartDoc2.ReleaseReference
second implementation is:
ThisApplication.Documents.CloseAll True
