in reply to: briant.markham
This is the path to the application:
"C:\Program Files\Autodesk\Inventor XXXX\Bin\InventorView.exe"
If it is still installed, you should be able to fire it up maunally. Or, if you right click on your desktop and select "New" then "Shortcut", ypu can just paste the path into the shortcut wizard, for example "C:\Program Files\Autodesk\Inventor 2019\Bin\InventorView.exe"
Once you have a shortcut, copy it into this location
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk Inventor XXXX
XXXX denotes the version for example 2019.
By default 2020 onwards installs with Inventor Read-only Mode, not Inventor View
