08-26-2020
12:31 PM
- Mute
- Permalink
- Report
08-26-2020
12:31 PM
Pulled directly from the API help file.
Public Sub CreateCustomProperties()
' Get the active document.
Dim invDoc As Document
Set invDoc = ThisApplication.ActiveDocument
' Get the user defined (custom) property set.
Dim invCustomPropertySet As PropertySet
Set invCustomPropertySet = invDoc.PropertySets.Item("Inventor User Defined Properties")
' Declare some variables that will contain the various values.
Dim strText As String
Dim dblValue As Double
Dim dtDate As Date
Dim blYesOrNo As Boolean
' Set values for the variables.
strText = "Some sample text."
dblValue = 3.14159
dtDate = Now
blYesOrNo = True
' Create the properties.
Dim invProperty As Property
Set invProperty = invCustomPropertySet.Add(strText, "Test Test")
Set invProperty = invCustomPropertySet.Add(dblValue, "Test Value")
Set invProperty = invCustomPropertySet.Add(dtDate, "Test Date")
Set invProperty = invCustomPropertySet.Add(blYesOrNo, "Test Yes or No")
End Sub
For a yes/no custom iProperty you will need to provide a variable with a boolean type.
Best of luck!
