08-25-2020
08:30 PM
- Mute
- Permalink
- Report
08-25-2020
08:30 PM
Hello
Can anyone check below i-logic code?
Dim propertyName1 As String = "Rev Desc" Dim propertyValue1 As String = "" customPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties") Try prop = customPropertySet.Item(propertyName1) Catch customPropertySet.Add("", propertyName1) End Try Dim propertyName2 As String = "Rev Date" Dim propertyValue2 As String = "mm/dd/yyyy" customPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties") Try prop = customPropertySet.Item(propertyName2) Catch customPropertySet.Add("mm/dd/yyyy", propertyName2) End Try Dim propertyName3 As String = "Salvagnini Proficient" Dim propertyValue3 As String = "Yes" customPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties") Try prop = customPropertySet.Item(propertyName3) Catch customPropertySet.Add("Yes/No", propertyName3) End Try
The problem on the result i have is the "Rev Date" shown as text meanwhile the purpose i need is "Date"
and the 2nd one on string "Salvagnini proficient" it's needs to be a multpile choices 'YES'NO"
Please see attached the wrong result and what i need.
