08-18-2020
04:33 AM
- Mute
- Permalink
- Report
08-18-2020
04:33 AM
Combining iLogic with an iPart factory inside the part itself is not a good idea. Your best option is probably to expand your iPart factory and get rid of the iLogic inside your part, this shouldnt be too much work.
If you have iPart member A and you use iLogic to supress feature 1 depending on a parameter value
you can simply make more iPart variants;
Member A1 (iPart A with feature 1 unsupressed)
Member A0 (iPart A with feature 1 supressed)
You can use iLogic inside your assembly to check the iPart parameter values etc, so you dont loose any information or flexibility
