dutt.thakar
Hello @Anonymous ,
As far as I know, it is not a good practice to use iParts factory with iLogic rules, as it will always update within the factory but will no carry forward the latest state in to assembly. The reason is, when we are placing an iPart component in an assembly, we are actually placing an instance that is created from factory iPart and not the actual factory part, so when you have iLogic inside it, it will update the factory but will not again generate and reflect the up to date member, to do that you need to open the factory and press update. I would rather not use iLogic for this and directly use iPart table to suppress all the feature that you have suppressed with iLogic and then it works best.
If this has answered your question, please accept this as solution.
Dutt Thakar
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
