08-17-2020
03:58 AM
- Mute
- Permalink
- Report
08-17-2020
03:58 AM
When you have that rule open within the iLogic rule editor dialog, on the options tab above, did you have the option "Straight VB Code" turned on? Was the contents of this rule meant to be shared between other iLogic rules? Did you start the code with "Class ThisRule", and end the code with "End Class"?
Can you share your code here, and tell us what it is supposed to be doing, so we can attempt to 'proofread' it, for errors?
Wesley Crihfield
(Not an Autodesk Employee)
