08-14-2020
05:19 AM
- Mute
- Permalink
- Report
08-14-2020
05:19 AM
As the title suggests, im trying to make iLogic create a Detail View, like so (done manually with UI);
I have the following code:
Dim oPointDetail As Point2d
oPointDetail = oView2.Center
oPointDetail.X = oPointDetail.X - 0.5 * oView2.Width
Dim oCurveSeg As DrawingCurveSegment
oCurveSeg = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Pick")
Dim oCenterPoint As Point2d
oCenterPoint = oCurveSeg.StartPoint
Dim oDetailView As DetailDrawingView
oDetailView = oSheet.DrawingViews.AddDetailView(oView2, oPointDetail, kFromBaseDrawingViewStyle, True, oCentrePoint, 1, , oView2.Scale * 3, True, "Detail A")
i ran into two problems:
1. i get an error with the cause 'wrong paramater', after looking at it i found out why;
The property 'StartPoint' returns nothing when the selected DrawingCurveSegment is circular (which mine is).
How can i work around this?
2. I use a manual picker to select a DrawingCurveSegment right now, which is fine for testing, but i want this automated. The segment i need a detail of is always the same, so the goal is to define that segment in my iLogic and assign it to oCurveseg
Thanks in advance.
