Hi @felix.cortes5K3Y2
It's strange, but it seems there is no way to use Measure.MinimumDistance to measure the distance between an entity in a component and an entity in the top level assembly...
Then we'll have to use more advanced API functionality:
Sub Main
Dim oAsm As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oAsmComp As AssemblyComponentDefinition = oAsm.ComponentDefinition
	Dim oUM As UnitsOfMeasure = oAsm.UnitsOfMeasure
	Dim Splice As ComponentOccurrence
	Splice = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select a splice plate")
	'Create a proxy for Face0 (The face in the context of the assembly)
	Dim oFace0 As Object
	Splice.CreateGeometryProxy(GetNamedEntity(Splice.Definition.Document, "Face0"), oFace0)
	'Get the XZ Plane of the assembly
	Dim oXZplane As WorkPlane = oAsmComp.WorkPlanes.Item("XZ Plane")
	'Measure distance
	Dim Height As Double = ThisApplication.MeasureTools.GetMinimumDistance(oFace0, oXZplane)
	'Convert distance from database units to default units of the document
	Height = oUM.ConvertUnits(Height, UnitsTypeEnum.kDatabaseLengthUnits, oUM.LengthUnits)
	'Return the value in a messagebox just to control that it's right
	MsgBox(Height)
End Sub
Public Function GetNamedEntity(doc As Inventor.Document, name As String) As Object
    Dim attribMgr As AttributeManager = doc.AttributeManager
    Dim objsFound As ObjectCollection
    objsFound = attribMgr.FindObjects("iLogicEntityNameSet", "iLogicEntityName", name)
    If objsFound.Count > 0 Then
        Return(objsFound.Item(1))
    Else
        Return(Nothing)
    End If
End Function
