shiftctrl.io
in reply to: JhoelForshav
Your solution is quite brilliant. Your answer most certainly solved the problem of adding the desired planes in the condition shown, however, part of the reason why I noted that a engineer would select two sides is that the rectangle (or cabinet) might at times have a vertical divider. In said case, do you have any suggestions to modify the logic so that it would apply the planes within the desired partition?
I should have asked this question with the following image in the beginning, though didn't anticipate such an elegant solution.
