- Mute
- Permalink
- Report
Event Trigger on Vault Check-In
We're interested in rolling out some automation to our company that checks certain iProperties before allowing a user to check in a model. Is there any way to trigger a rule "Before Check-In" or to write custom triggers?
Tighe
- Mute
- Permalink
- Report
What version of vault are you using?
Arthur Knoors
Autodesk Affiliations:
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Based on using an add in for inventor you could use the prevaultcheckinevents!
Don't know if this is what you want.
For ilogic I don't know if this is possible easily!
Arthur Knoors
- Mute
- Permalink
- Report
it can be done in addin troug OnActivateCommand event:
for example:
Private Sub ui_OnActivateCommand(CommandName As String, Context As NameValueMap) Handles oUserInputEvents.OnActivateCommand
On Error Resume Next
Select Case CommandName
Case "VaultCheckin"
'or
Case "VaultCheckinTop"
End Select
End Sub
- Mute
- Permalink
- Report
this is not before, and will not trigger before
This is only if the command is activated.
Arthur Knoors
- Mute
- Permalink
- Report
I was using this approach before i switched to vault api DocumentService.AddFileEvents.Pre and DocumentService.CheckinFileEvents.Pre events. and to be honest i still use it because when you will use documentservice your code will be fired after you click ok in vault check in window in inventor.
when using on activate command the code will be fired before vault check in window will be displayed, for me this one is better because i will finnish all before gatering check in files.
