08-06-2020
09:07 AM
- Mute
- Permalink
- Report
08-06-2020
09:07 AM
If you edit the hole note manually to the way you want it in 2019 does it crash or give you any errors?
If not, try this:
Edit a hole note the way you want it manually, then using an InputBox code from an iLogic rule, with the oHoleNote.Text.FormattedText as the 'default response' entry at the end of the InputBox code. This will show you the fully selectable & copyable formatted text. Then copy that to use within your code.
Wesley Crihfield
(Not an Autodesk Employee)
