08-03-2020
03:10 AM
- Mute
- Permalink
- Report
08-03-2020
03:10 AM
I'm not sure what your code did, or If I just don't understand how to use it.
However, I think maybe your code is a bit too complicated for its use? Maybe I'm wrong.
I've looked a bit around and found out that this short code does almost what I need it to do.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
iProperties.Value("Custom", "Temp PartNum") = iProperties.Value(oOccurrence.Name, "Project", "Part Number")
Next
Now I just need the 'Next' at the end to wait for user input istead of being automatic. I guess this is what you did with following code:
Dim oIndex As Integer
Dim oLastOne As Integer
If
oIndex = oLastOne + 1
Else
oIndex = 1
With the code first code in this post, I have a custom property called "Temp PartNum", which will tell the user which part is currently active for edits.
If I get this "next part" (the code above) button to work, all others iProperties I will be able to fix myself.
