Justin,
First of all, my code is suited for VBA, and not iLogic.
If you just have copy-pasted my code in iLogic you will get even more errors after 'fixing' the first one. :slightly_smiling_face:
I suggest you read over my used code as a guide to see how I tackled the problem.
Then you can modify it to your needs/use bits and pieces of it so you understand the script you are making.
(You can ignore the 'Textfile' calls because I did not gave you those lines of code.)
