  • Is this form an iLogic form, and not a Windows.Forms.Form?
  • If this for is an iLogic form, is it stored locally within the assembly document, or is it a Global Form?
  • If it is a VBA UserForm, is its module within the assembly document's project, or within the main default application project.
  • Do you only want to cycle through the PartDocuments that are within the active assembly, or do you want to cycle through sub-assemblies too.
  • If you want to cycle through sub-assemblies, do you also want to cycle through each part within each level of each sub-assembly. How many layers deep do you want to go within the sub-assemblies?
Wesley Crihfield
(Not an Autodesk Employee)
