WCrihfield
in reply to: shaun59G6W
Here's one way of doing it.
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
	MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Drawing Documents.",vbOK, "WRONG DOCUMENT TYPE")
	Return
End If
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim oOtherDocPath As String = "C:\Temp\MasterDrawing.idw"
Dim oOtherDrawing As DrawingDocument = ThisApplication.Documents.Open(oOtherDocPath,False)
For Each oSheet As Sheet In oDDoc.Sheets
	If oSheet.Name.Contains("Shop") Then
		oSheet.CopyTo(oOtherDrawing)
	End If
Next
Wesley Crihfield
(Not an Autodesk Employee)
