in reply to: WCrihfield
Problem solved.
The "LastKnownSourceFile" is correct. But I copied the template and renamed the file, to check the code.
What I didn't know was, that each template have a unique ID. So for both the ID is the same and the API give the same file as the template back.
It's a little bit confusing, because the API shows another file as the frontend.
