1855 Views, 11 Replies
07-15-2020
04:33 PM
- Mute
- Permalink
- Report
07-15-2020
04:33 PM
Create 3d spline from excel worksheet using VBA
I need to automate the following action using VBA:
In the user interface, with a Part file open, I select "Start 3D Sketch"
In the Insert Panel, I select "Points" (which causes a File Open dialog box to open)
Because I want a 3D Spline curve, I click on Options and select "Create Spline"
I select an Excel workbook file that contains rows with X, Y, Z coordinate information, one row for each point
The information in the Excel workbook is imported, the points are created, and a spline curve created through them
Can this action be accomplished using VBA, and if so, how.
Thanks.
command from the "Insert" panel
