omartin
in reply to: ABoaro
I pretty sure the 'limit' is what your for loop is counting to, seems like it is not being set, if you are getting a value from the f1 column it may need to be converted to integer first. I dont have access to inventor right now so im just going off the top
Was my reply Helpful ? send a Kudos or accept as solution
