@ckeveryga,
On running below code, throws System.NotImplementedException: 'Not implemented (Exception from HRESULT: 0x80004001 (E_NOTIMPL))' error. It means that method is not implemented in apprentice.
oOcc.Definition.BOMQuantity.GetBaseQuantity(out qType, out qQTY);
The API exposed by Apprentice is a subset of the complete Autodesk Inventor API. Apprentice provides access to file references, assembly structure, B-Rep, geometry, attributes, render styles, and document properties. Access to the assembly structure, B-Rep, geometry, and render styles is read-only. Access to file references, attributes, and document properties is read and write.
The primary differences between Autodesk Inventor and Apprentice are in the Application and Document objects. The objects that represent the Application and Document are completely different in Autodesk Inventor and Apprentice. The Apprentice Application object is called ApprenticeServerComponent. It supports a much more limited API than the Inventor Application object. In Apprentice there isn't a Documents collection.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
