omartin
in reply to: ABoaro
I have not used goExcel myself, but I read it has a lot of finickey behaviour. you can do a small test to ensure that file is being loaded properly with xlsm, otherwise it is some other object that is failng on assignment, you can use is the, "is nothing" to check for null objects
Best Regards
Was my reply Helpful ? send a Kudos or accept as solution
