The iLogic does not make a Zip-file.
It still makes the DXF-files, but does not place them into a Zip-file.
For the name issue, I would like to have that the Zip-file has the name of the idw-file.
Now the DXF-files get the name of the idw-file.
Bellow you can find the text, should i change anything else maybe?
Q:\Projecten\Projecten algemeen\DXF Instellingen(2)\DXF-instellingen.ini
[EXPORT SELECT OPTIONS]
AUTOCAD VERSION=AutoCAD 2010
CREATE AUTOCAD MECHANICAL=No
USE TRANSMITTAL=Yes
USE CUSTOMIZE=No
CUSTOMIZE FILE=C:\Users\Public\Documents\Autodesk\Inventor 2020\Design Data\DWG-DXF\FlatPattern.xml
CREATE LAYER GROUP=No
PARTS ONLY=Yes
[EXPORT PROPERTIES]
SELECTED PROPERTIES=
[EXPORT DESTINATION]
SPACE=Model
SCALING=Full
ALL SHEETS=Yes
MAPPING=MapsBest
MODEL GEOMETRY ONLY=Yes
EXPLODE DIMENSIONS=No
SYMBOLS ARE BLOCKED=Yes
AUTOCAD TEMPLATE=
DESTINATION DXF=Yes
USE ACI FOR ENTITIES AND LAYERS=No
[EXPORT LINE TYPE & LINE SCALE]
LINE TYPE FILE=C:\Users\Public\Documents\Autodesk\Inventor 2020\COMPATIBILITY\Support\invDIN.lin
Continuous=Continuous;0,
Dashed=DASHED;0,
Dashed Space=DASHED_SPACE;0,
Long Dash Dotted=LONG_DASH_DOTTED;0,
Long Dash Double Dot=LONG_DASH_DOUBLE_DOT;0,
Long Dash Triple Dot=LONG_DASH_TRIPLE_DOT;0,
Dotted=DOTTED;0,
Chain=CHAIN;0,
Double Dash Chain=DOUBLE_DASH_CHAIN;0,
Dash Double Dot=DASH_DOUBLE_DOT;0,
Dash Dot=DASH_DOT;0,
Double Dash Dot=DOUBLE_DASH_DOT;0,
Double Dash Double Dot=DOUBLE_DASH_DOUBLE_DOT;0,
Dash Triple Dot=DASH_TRIPLE_DOT;0,
Double Dash Triple Dot=DOUBLE_DASH_TRIPLE_DOT;0,
