thomas.vanhaecke
514 Views, 4 Replies
Make DXF and place in compressed file Ilogic
Hey,
I was using inventor 2012, recently we upgraded to 2020.
In inventor 2012 i was using the following ilogic to create from one idw-file the dxf-files and place them into an compressed file.
Whit upgrading to inventor 2020 the rule makes the dxf-files but does not place them into an compressed file.
Can anyone maybe help me with my  problem?
Also the compressed file had in inventor 2012 no name assigned.
This would be great to if i could add this, the name should be the same as the idx-file.
'query user
question = MessageBox.Show("is a .DXF Export Required", "iLogic Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'set condition based on answer
If question = vbYes Then
' Get the DXF translator Add-In.
path_and_nameDXF = ThisDoc.Path & "\"
Dim DXFAddIn As TranslatorAddIn
DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
Dim strIniFile As String
strIniFile = "Q:\Projecten\Projecten algemeen\DXF Instellingen(2)\DXF-instellingen.ini"
oOptions.Value("Export_Acad_IniFile") = strIniFile
End If
oDataMedium.FileName = path_and_nameDXF & ".dxf"
Call DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End If
