WCrihfield
in reply to: arkelec
When you specify the thickness parameter within the iFeature, are you using a number or the actual parameter name "Thickness" directly?  If I put the name "Thickness" (without the quotes) in as the thickness value, it always identifies the identically named Parameter in the target model file and uses its value.
Wesley Crihfield
(Not an Autodesk Employee)
