07-01-2020
07:17 AM
- Mute
- Permalink
- Report
07-01-2020
07:17 AM
I have a program that loops through an assembly using component occurrences in Inventor. The following code to access the BOM Quantity Type works fine in Inventor:
oOcc.Definition.BOMQuantity.GetBaseQuantity(out qType, out qQTY);
When I try to run the same code using Apprentice, I get the following error: (Exception from HRESULT: 0x80004001 (E_NOTIMPL))
Does anyone know if it is possible to access this property through apprentice? I have been able to access all other properties in the same way that I would with Inventor, until this error.
Relevant section of code:
public void Loop(ComponentOccurrence oOcc)
BOMQuantityTypeEnum qType;
object qQTY;
C# as programming language
Autodesk Inventor 2019, Build: 330, Release: 2019.4.1
