bevansGP8JU
in reply to: kelly.young
@kelly.young @johnsonshiue
Thank you for the prompt response and the warm welcome, I've been using 'top level' Inventor for about 4 years, just now getting into the customization bits.
@kelly.young, can I use assembly-level parameters to control part-level features without iLogic? That's how I have it set up right now
Parameter("MM-GARD-XXXXX-005:1", "Length") = sparWidth
For example, this line assigns the parameter "Length" from part MM-GARD to be equal to the assembly level parameter 'sparWidth'
As I understand it, that's the most efficient way to manipulate multiple relevant part parameters from the assembly level document.
@johnsonshiue Something to note, I was unable to find the iLogic Design tool you were referring to, but perhaps it is because we are using cursed software, Inventor 2014!
