kelly.young
in reply to: bevansGP8JU
Hello @bevansGP8JU I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
You may want to investigate creating a fully parametric model (possibly using derived parts) and then using Vault Copy Design or iLogic Design Copy. This way you can pick and choose which files you want to reuse and which to duplicate, rename, and replace.
Worked well for me by creating templates and then for each customer would use Vault Copy Design to rename the frame, casing, door, etc with customer name at the Prefix.
Please select the Accept Solution button if a post solves your issue or answers your question.
