- Mute
- Permalink
- Report
Inventor new instance on close
Hey
im having a small issue with an invisible document appearing in my taskbar when i close inventor. This appears mainly after i run my app so i mustn't be closing something properly. In summary, here is my document open / save close process
1. Import step file using translator (no open file before import)
Call oSTEPTranslator.Open(oDataMedium, oContext, oOptions, oTarget)2. Create a document view from the import
Dim oDoc As Inventor.Document = oTarget
oDoc.Views.Add()3. Process all of the components in this document (not saved yet)
4. Rebuild & update active assembly (document from step 1)
5. Create a temp doc to hold the original ActiveDoc
Dim OldDoc As Inventor.AssemblyDocument = AddinGlobal.InventorApp.ActiveDocument6. SaveAs the current ActiveDoc into a new location
AddinGlobal.InventorApp.ActiveDocument.SaveAs(PathRoot & AssyName & ".iam", True)7. Open the newly saved document as a new assembly
Dim NewDoc As Inventor.AssemblyDocument = AddinGlobal.InventorApp.Documents.Open(PathRoot & AssyName & ".iam", True)8. Close the old doc that i created as the ActiveDoc prior to saving
OldDoc.Close(True)9. Iterate assembly and SaveAs all components then replacing them in the assembly for the saved ones
This should leave 1 assembly active (the new one) and the old ones closed or is that not the case? Does item 2 actually create another document and is that the rogue document? Somewhere in this process is an invisible document. For every other process, i pass the ActiveDocument through instead creating document instances for example-
Private Sub DoSomething()
'process stuff here
Call NextSub(_InvApp.ActiveDocument)
End Sub
Private Sub NextSub(ByRef CurrDoc As AssemblyDocument)
'do something with CurrDoc
End Sub
The problem highlights when a new project is initiated as all documents need to be closed...
Any help greatly appreciated
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
- Mute
- Permalink
- Report
A little hard to follow, but kind of sounds like this built-in iLogic Sub may be able to help.
Dim oDoc As Document
oDoc.ReleaseReferenceI only put the Dim oDoc As Document, in there to activate iLogic Rule Editor's intellisense type ability, to show what id does.
Wesley Crihfield
(Not an Autodesk Employee)
