- Mute
- Permalink
- Report
Section View Label in Base View (Not require symbol to complete)
Hi I've been researching to find a solution but all solutions required adding a symbol to the library (Template). Is there a solution that just lets you edit this feature? (See picture below) I've looked into the formattedtext property and I thought that might be the solution but it seems to edit both fields.
Tiffany Hayden
- Mute
- Permalink
- Report
i am trying to do the same thing as you. unfortunately that label & the detail view label are not exposed to the api. You can manually edit them and delete the text but not by code im afraid
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
- Mute
- Permalink
- Report
I just wanted to draw your attention to this post. It will most likely help someone. It sounds like the bulk of the work is complete. I have yet to implement and test.
Or if this helped you, please, click (like)
Regards
Alan
- Mute
- Permalink
- Report
Thank you @A.Acheson I'll take a look!
Tiffany
Tiffany Hayden
