fullevent
in reply to: moraesorlando
Are the files you want to copy in the same directory as your assembly?
Otherwise, I don't know what else it could be..
Or maybe there is something wrong with the file names and you have to adjust.
sFilesToCopy(0) = "DEPT-YYYY-XXX-05-01 SUPPORT.ipt"
sFilesToCopy(1) = "DEPT-YYYY-XXX-05-01 SUPPORT.dwg"
sFilesToCopy(2) = "DEPT-YYYY-XXX-04-01 EXTERNAL PLATE.ipt"
sFilesToCopy(3) = "DEPT-YYYY-XXX-04-01 EXTERNAL PLATE.dwg"
sFilesToCopy(4) = "DEPT-YYYY-XXX-03-01 INTERNAL PLATE.ipt"
sFilesToCopy(5) = "DEPT-YYYY-XXX-03-01 INTERNAL PLATE.dwg"
sFilesToCopy(6) = "DEPT-YYYY-XXX-02-01 SIDE LEFT PLATE.ipt"
sFilesToCopy(7) = "DEPT-YYYY-XXX-02-01 SIDE LEFT PLATE.dwg"
sFilesToCopy(8) = "DEPT-YYYY-XXX-01-01 SIDE RIGHT PLATE.ipt"
sFilesToCopy(9) = "DEPT-YYYY-XXX-01-01 SIDE RIGHT PLATE.dwg"
regards,
Aleksandar Krstic
Produkt- und Projektmanager
