RockieM
456 Views, 4 Replies
Title Block doesn't update custom iproperties driven from ilogic rule
Hi there,
I have an ilogic rule helps automate most of our revision processes.  It populates a number of iproperties in the model document, some being normal iproperties and a number of custom iproperties.  These then populate in the .idw flawlessly unless the model document is an assembly with any sort of Representation involved (View, Position, LOD).  I have 7 users using my rules who always bring this to my attention, so I want remedy this so I don't run into this again.
I do have this at the end of my code: InventorVb.DocumentUpdate()  but it doesn't update.
Manually I can get it to work by saving the file, moving the base view in the idw a bit and then update in the file which is normally greyed out until I move the base view.
Update Copied Properties doesn't work for this
Anybody have any ideas on this?
Thanks!@
Rockie (Inventor 2019)
