06-09-2020
05:29 AM
- Mute
- Permalink
- Report
06-09-2020
05:29 AM
I have the code below that opens a drawing "silently" and adds a sheet with a border and title block to it. I need to do a zoom all on the sheet but can't figure out how to do it when the drawing is silent. There are no views on the sheet yet, it is just a blank sheet. Can anybody point me in the right direction? Thanks in advance!
'Open the drawing template silently dwgFile = ThisDoc.Path() & "\Dwgs\Musco Pole.dwg" '<- Change Drawing name here Dim oDrawDoc as DrawingDocument = ThisApplication.Documents.Open(dwgFile, False) Dim oSheet2 As Sheet oSheet2 = oDrawDoc.Sheets.Add oSheet2.Activate oSheet2.Name ="Layout2" oSheet2.ExcludeFromPrinting = False oSheet2.ExcludeFromCount = False 'get current size Dim Size As DrawingSheetSizeEnum Size = oSheet2.Size 'set new size oSheet2.Size = DrawingSheetSizeEnum.kBDrawingSheetSize Dim oBorder As Border = oSheet2.Border Dim borderDef As BorderDefinition oSheet2.AddBorder("PiRod Border") '<- Change Border name here Dim oTitleBlock As TitleBlock = oSheet2.TitleBlock Dim TitleBlockDef As TitleBlockDefinition oSheet2.AddTitleBlock("Plymouth") '<- Change Title Block name here'ThisApplication.ActiveView.Fit '<- This doesn't work because the drawing is not the active document 'update sheet to see results oSheet2.Update
