06-06-2020
05:50 AM
- Mute
- Permalink
- Report
06-06-2020
05:50 AM
Hi, i found the problem that i had last knight. the command form was closed but the command it self was not finished. i had to force it to stop. That did the trick. Below you find the working code. I also removed some code that could that loops over all nodes tofind the correct Browserpane and nodes. (and i used my own code from you previous question;-)
Public Class ThisRule Private busy As Boolean = False Sub Main() ' Get the collection of control definitions. Dim oControlDefs As ControlDefinitions = ThisApplication.CommandManager.ControlDefinitions Dim oControlDef As ControlDefinition = oControlDefs.Item("AEC_Exchange:Command:Connector:Edit") ' check if this document is a part document If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then MessageBox.Show("The current document must be a part file", "Incorrect Document Type") Return End If 'Enter the BIM Content environment ThisApplication.CommandManager.ControlDefinitions.Item("AEC_Exchange:Environment").Execute() 'Access the Browser and Activate the "Bim Content" Browser Pane Dim oPartDoc As PartDocument = ThisDoc.Document Dim bps = oPartDoc.BrowserPanes Dim bimContentPane As BrowserPane = oPartDoc.BrowserPanes.Item("AEC_Exchange:Browser") 'Define the Appearance variables Dim oElecAppearance As Asset = oPartDoc.Assets.Item("Connection_Electrical") Dim oMechAppearance As Asset = oPartDoc.Assets.Item("Connection_Mechanical") Dim oPipeAppearance As Asset = oPartDoc.Assets.Item("Connection_Piping") 'Define the BIM Component Information Dim oPartDocBIM As BIMComponent = oPartDoc.ComponentDefinition.BIMComponent 'Check through each Face on the body and see if uses the special appearance. For Each oSrfBody As SurfaceBody In oPartDoc.ComponentDefinition.SurfaceBodies For Each oFace As Face In oSrfBody.Faces If oFace.Appearance.DisplayName = oElecAppearance.DisplayName Then Dim Elec_Coll As ObjectCollection Elec_Coll = ThisApplication.TransientObjects.CreateObjectCollection Elec_Coll.Add(oFace) 'Create Electrical Connector Definition Dim oElecConn As BIMElectricalConnectorDefinition oElecConn = oPartDocBIM.Connectors.CreateElectricalConnectorDefinition(Elec_Coll) oElecConn.SystemType = BIMElectricalSystemTypeEnum.kPowerBalancedElectricalSystemType 'Add the Electrical BIM Connection Dim con As BIMConnector = oPartDocBIM.Connectors.Add(oElecConn) con.Name = "Elec_Conn_" & oPartDocBIM.Connectors.Count Dim systemNode As BrowserNode = bimContentPane.TopNode.BrowserNodes.Item("MEP System Connections") Dim electicalNode As BrowserNode = systemNode.BrowserNodes.Item("Electrical") electicalNode.Expanded = True Dim oConnNode As BrowserNode = electicalNode.BrowserNodes.Item(con.Name) oConnNode.DoSelect() oControlDef.Execute() Dim docEvents As DocumentEvents = ThisApplication.ActiveDocument.DocumentEvents AddHandler docEvents.OnChange, AddressOf docEvents_OnChange busy = True While (busy = True) System.Threading.Thread.Sleep(50) ThisApplication.UserInterfaceManager.DoEvents() End While RemoveHandler docEvents.OnChange, AddressOf docEvents_OnChange ThisApplication.CommandManager.StopActiveCommand() End If Next Next End Sub Private Sub docEvents_OnChange(ReasonsForChange As CommandTypesEnum, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) If (BeforeOrAfter = EventTimingEnum.kAfter And Context(1) = "API Change") Then busy = False End If End Sub End Class
Jelte de Jong
Blog: hjalte.nl - github.com
